SunVisor Wiring Question...
Old Jun 23, 2007 | 10:31 PM
1buddyc's Avatar
Does anyone know if the Wiring is already in place in the roof area, above the Headliner, for Lighted Visors on an '06 Supercrew with the Standard, non lighted Visors? Thanks in advance for any guidance/advice
Old Jun 24, 2007 | 03:25 PM
SSCULLY's Avatar
my '06 has the illuminated / homelink visors installed already, so I can't say for sure.
My '01 XLT SCrew did not come with them, but I ordered the Lin Nav visors, and the harness was taped back against another loom over the door opening. Took out the A-pillar trim panel, and the visor, and I could pull down the head liner enough to see it.
Mind you this is on a 2001 MY truck, not a 2006 MY truck.
The connector was a 2 pin ( 3 pin ? ) small connector.
Worth a look. Remove the A-pillar trim panel, the rubber over the door, and the visor to check for the connector if you have a XLT. If you have a XL, chances are it is not there, but worth a look any way.
Sorry, hope someone else comes by with a firm answer one way or the other.
Old Jun 25, 2007 | 11:59 AM
1buddyc's Avatar
Thanks SSCULLY, will look in to it. Anyone else have any other recommendations?
Old Jun 28, 2007 | 11:21 AM
1buddyc's Avatar
Anyone else???
