temp reading on odometer is outta sight......
Old Jun 16, 2007 | 12:55 AM
belt-loop's Avatar
2004/150/4x4 odometer reading for direction is accurate, mileage reading is good BUT the outside temperature reading is way outta site .
Yesterday 85 degrees here but reading showed a wopping 114 degrees and sometimes upto 118 ; today temp reading was 126 degrees...
how is this fixed....
thanks
belt-loop at *** dot net
Old Jun 16, 2007 | 12:59 AM
belt-loop's Avatar
temp
Btt
Old Jun 20, 2007 | 08:28 PM
RUSS04's Avatar
thanks
My outside temp reading just started acting up today Looks like a trip to the dealer is on order for me
Old Jun 21, 2007 | 02:39 PM
thebigbc's Avatar
I dont even understand how it works. Is it the little black box behind the rear view that is taking the reading? Cuz when I get in my truck here in florida, it says that it is 100 degrees, but then if i roll down the windows and let it air out it goes down to the temp outside. does that make sense? Is that how it is supposed to work?
Old Jun 21, 2007 | 04:36 PM
LRG's Avatar
LRG
No the black box behind the mirror is for the digital compass. The outside temp sensor is behind the grill in front of the radiator. Here's a good thread to check out on it: https://www.f150online.com/forums/sh...erature+sensor.
Old Jun 21, 2007 | 09:17 PM
RUSS04's Avatar
Thank you for the the info LRG I will try to fix it my self before i take it back to the dealer
