Ebay Keyless Remotes
Old Jun 7, 2007 | 04:37 PM
LT.Smash's Avatar
I have a 1998 F-150 4x4 XLT. I bought it at an auction and so far love it. I noticed that it did not come with a keyless remote. I assumed they lost it. I checked the to see if it had the factory keyless system by turning the key off and on 8 time. The doors locked and then unlocked and from what I understand this means that I have a factory keyless entry system.
Here is my question:
Will the Ebay "f150 remotes" as long as the description says "for 98+" work for my vehicle or should I go somewhere else to purchase this?
Old Jun 7, 2007 | 05:14 PM
SuperLB51's Avatar
They should work just fine I would think...
Old Jun 7, 2007 | 08:02 PM
1/2Breed's Avatar
Spare Fob
When I bought my 97' F-150 it only had one Remote. I bought one off of E-bay[at about 1/3 the cost of Ford] I programed it just as the instruction said . It works perfectly.
Old Jun 7, 2007 | 10:07 PM
Steve83's Avatar
Read to the bottom of the caption of this diagram:
Then use the PREV/NEXT links to read the rest of the TSB, or use the album link at the top to view all the thumbs.
Old Jun 8, 2007 | 09:52 AM
LT.Smash's Avatar
Hey thanks guys. I will try make sure I get the remote for the 98+ (with the icons, not words). I will post back so that everyone knows how it works for me.
Old Jun 8, 2007 | 11:21 AM
twintips_17's Avatar
Is this the way to check to see if you have Keyless entry? What is the exact way?
Old Jun 8, 2007 | 04:33 PM
SSCULLY's Avatar
The directions for programming RKE fobs :
Entering programming mode will tell you if the RKE feature is installed.
This was not in the '98 & '99 owners manuals, but 2000+ it is.
Works on previous years. Watch the time between completing steps. My '01 I took 3 times to enter programming mode, to add a 3rd RKE. I really had to haul through the on-off sequence, to enter programming mode.
If you want to down load a '01 owners manual, so you can print the full size page :
https://www.fleet.ford.com/maintenan...ls/default.asp
Old Jun 8, 2007 | 06:18 PM
Steve83's Avatar
Originally Posted by SSCULLY
The directions for programming RKE fobs...
...can also be found in the caption of that diagram I posted above.
Old Jun 9, 2007 | 10:02 AM
SSCULLY's Avatar
Ooopss..... At least I am not alone in not reading your Supermotors page
Old Jul 6, 2007 | 03:56 PM
LT.Smash's Avatar
Hey excellent info guys.
As for the ebay keyless remotes... they work. I bought mine for around $12 after shipping. Much better than the $45 at a dealer. Range seems to be a bit short but it could be that way with all of them for all I know. It also came with a battery already installed in the remote and worked right out of the package.
Old Jul 6, 2007 | 04:04 PM
yekratsb's Avatar
The eBay FOB's absolutely work. When I bought the truck, FOB's were missing, however the little trick with the inginition steps verified that the keyless module was in place.
Couple minutes of eBay searches and I found these guys:
http://stores.ebay.com/Car-and-Truck-Remotes
Took 3 minutes to setup 2 brand new FOBS. Instructions were included. $27.00 for 2.
Old Jul 7, 2007 | 06:53 PM
vigness's Avatar
Question
I seem to recall somewhere that the unit can be put into fleet mode for up to 20 keys. I know that applies to keys, wonder if that corelates to remotes as well?
