Keyless entry honk
Old May 15, 2007 | 03:40 PM
jaws12's Avatar
Keyless entry honk
I got a keyless entry system put on awhile back and i like it except for one thing. when i lock the doors it doesnt honk. well i wired up my horns to the lock motor, with a fuse, and now when i lock it the horn blows.
the problem is the horn blows for like 1-2 seconds. stock sytems have a short beep when you lock the doors. well i want mine to do this and not have a long beeeeeep to it.
i think my relay just makes contact for too long, is there a relay that will have a shorter contact time or is there another way to get the horns to just beep, instead of beeeeeeeep.
like i said the setup works fine except the horn stays on too long
any ideas
josh
Old May 17, 2007 | 06:06 AM
jaws12's Avatar
noone knows how to make my horn blow a short beep when i lock the doors???
Old May 17, 2007 | 08:04 AM
06 So Comfort's Avatar
Let me see if I have this straight...
You put an after market keyless entry system, by an unnamed vendor, on an unnamed vehicle, and you want us to troubleshoot it. Did I miss anything?
Seriously, a little more information would help. Maybe someone has used the product before. General suggestions:
Try reading the owner's manual - it may be a user-selectable option.
Try contacting the vendor.
Good luck.
Old May 18, 2007 | 02:09 AM
jaws12's Avatar
lemme try again
nevermind, it aint worth the trouble to make it honk anyways, im just glad i found the antenna and increased the area.
josh
Old May 18, 2007 | 03:30 AM
dennisfranz's Avatar
I know on my RKE that if I press it once it locks, twice confirms the lock with a short horn.
Old May 28, 2007 | 11:12 PM
NewOrleans4X4's Avatar
Yup my 2001 factory key fobber did the same, first push no honk, only honked on the second push of the button, too bad I lost it last week in Washington DC.
