Kill Switch
Old Apr 29, 2007 | 10:25 PM
Nedward's Avatar
Kill Switch
I would Like to wire up a simple Kill Switch in my truck. Anybody have any good ideas or experiances with this? I am going to try and make it look stock/hidden. Any comments will help.
Old Apr 30, 2007 | 12:21 AM
Steve83's Avatar
These are used as factory transport kill-switches on some Land Rovers, so they're certainly up to the task, and easy-to-find. I have several.
Here are a few possible ways to add it into a circuit.
Your starter wiring is SLIGHTLY different from that diagram (you have a wire straight from the battery to the starter solenoid), but you can still use those. Yours is like this:
As for physical locations, that'll depend (naturally) on how it's placed electrically, but for the "starter-disable" option, the passenger floorboard up under the dash would be good.
Old Apr 30, 2007 | 12:50 AM
lees99f150's Avatar
with PATS do you really need a kill switch?
Old Apr 30, 2007 | 01:31 AM
SSCULLY's Avatar
If you want to go with a lower AMP version
Kill switch inline with the fuel inertia switch :
https://www.f150online.com/forums/sh...hreadid=119057
Just another option to add to the list.
Old Apr 30, 2007 | 01:46 PM
rb4123's Avatar
Are you looking for a disable, or an actual shutdown like on a motorcycle? If it's a disable style, I would go with the one described in the link above.
