Wiring up interior neons
Old Apr 29, 2007 | 10:17 PM
weshova's Avatar
I got a couple neon light tubes this weekend and they plug into the cigarrete lighter and i plan on gettin a third one...my plan is to find the constant power wire that runs to the cigarrete lighter, then run a wire from that to a switch and then a wire from the switch to both neon tubes...ik this will light up and work but my question is that will the system be safe?? can 3 of them tubes be all wired straight into one?? will it blow any fuses or anything?? i just want to take all the precautions before messin up my truck...anywayz thanx for the info...o and also if theres a better or easier way to hardwire them lmk..thanx. wes
Old May 11, 2007 | 07:19 PM
minesmen's Avatar
wiring neon
what i did was, i got my power and ground from my radio. i ran then to a switch. i have 2 neon tubes,pedals, 3 led strips and 4 leds hook up that way. all using the same power and ground
havent had a problem.
Old May 13, 2007 | 11:15 PM
bigplayer6907's Avatar
neons draw very little current so this setup isnt that bad. if anything all you would need to do is put a little bit bigger fuse because that cuircut is now drawing more ampres. another way to do it would do be to use a relay if you kno how they work...
