2004 F150 SuperCrew
Old Apr 11, 2007 | 02:51 PM
kbailey's Avatar
Question 2004 F150 SuperCrew
I am having an issue with my 2004 F150 SuperCrew.
The lighter and 12V power outlet in the dash do not work. I have checked Fuse position #41 and everything looked normal i.e. 20A fuse. The 12V power outlet in the back works fine any suggestions?
Old Apr 11, 2007 | 03:07 PM
jmt0645's Avatar
check the back of the plug and be sure the harness is plugged in to it. cause when I returned to the dealer for maintenence, got home and plugged in an inverter for a cooler, it didn't work. Come to find out the clip that held the harness in the plug had gotten broke off somehow.
Old Apr 12, 2007 | 04:22 PM
SSCULLY's Avatar
What are you using to test with ?
If you are using the same item, such as a cell phone charger cord, check that the fuse in the tip is not blown.
The reason I bring this up, is you say the cigar lighter, and the power point both don't work, but thee are 2 separate fuses. You got F41 for the DLC and cigar lighter, but the instrument panel power point is Fuse #F39.
With it being a SCrew, try what you are testing with in the rear power point, which is Fuse #F37.
I would guess that what you are using to test has the problem, not 2 ( and until you check the rear ) 3 separate fuses.
