ok i need to ask a stupid question again
Old Apr 9, 2007 | 02:55 PM
cyndee's Avatar
ok my starter sylanoid went out so i replaced it myself lol
well i had one extra thing (i dont know what to call it)
left over that had the circle at the end of a wire casing
i hope that explains it
i have one of them attached to one side and two to the other
it starts but seems weird i was wonder ing if the red or the green are both supposed to be attached to the side that goes to the battery
ok does anyone have a picture that i can view so i can make sure it right
thank you
thank you
thank you
from a stupid girl
Old Apr 9, 2007 | 09:42 PM
cyndee's Avatar
starter sylanoid
did i post in the wrong area again????
Old Apr 9, 2007 | 10:25 PM
zambonimaxx's Avatar
I would try putting it in Engines...you will more than likely get a response there...if not here. Also take a picture of the thingy.
~Phil
Old Apr 10, 2007 | 07:43 AM
MGttrmn's Avatar
thank you
thank you
thank you
from a stupid girl
would that be a ringterminal. its crimped onto the wire?
Old Apr 10, 2007 | 02:41 PM
Bluegrass's Avatar
The red lead should go on the battery side.
A green, I can't say without more info and a check of service info unless someone has the same and can take a look for you..
What year is the truck?
Old Apr 10, 2007 | 04:41 PM
keith97xlt's Avatar
green is usually a ground wire. ive never seen a green wire though for starter wiring. when i replaced mine i remember putting the ground to one the bolts to the bellhousing.
Old Apr 10, 2007 | 05:35 PM
cyndee's Avatar
yes thats what it is
Old Apr 10, 2007 | 05:43 PM
cyndee's Avatar
they are telling me that it is a relay
