Cruise control works then doesn't work
Old Apr 1, 2007 | 08:39 AM
dallasstar's Avatar
Question Cruise control works then doesn't work
2002 Supercab XLT recall has been done on cruise control
My cruise control works only some times, the wierdest thing is that my horn works perfectly on the air bag pad but get this, when I press the cruise ON and Coast button at the same time, my horn goes off. This will work some of the time, then won't work, then start working again, alot light my cruise control but the 2 don' t seem to have a pattern. Cruise works, horn on controls work, then horn doesn't work and cruise works, then both don't work. What I've been reading it sounds to me like the clock spring, anyone have this happen to them. Any posts on a pic of a clock spring with the steering wheel still on whith the airbag removed.
Old Apr 1, 2007 | 11:36 AM
skooba's Avatar
Yes, It happens to me and i also think it is the clock spring. I've looked at wiring diagrams and that is just about the only thing that ties them together. I'm taking it to the dealer next weekend. Little to deep for me!!
Old Apr 1, 2007 | 01:49 PM
dallasstar's Avatar
Let me know how you make out.
Old Apr 1, 2007 | 04:02 PM
tomt's Avatar
I don't know if it has anything to do with your prob but I just got a recall for the cruise on my 03. something about it possibly catching on fire even when the key is not in the ignition.
Old Apr 1, 2007 | 06:05 PM
SSCULLY's Avatar
1. you did not make note n your post, of the question raised by tomt, did you have the CC recall repair performed on your truck ?
2. There is a self test in the cruise control system.
With the key off depress and hold the cruise control off button while turning the ignition to the run position,don't start the truck, the cruise light will flash once to let you know it is in self test.
Five additional flashes indicate a bad cruise control servo
Release the cruise off switch and within 5 seconds depress the other switches in sequence:
1. on
2. resume
3. coast
4. set/ accel
The speed control light will flash as each switch is depressed.
If the last one does not flash it may then flash a code
After this the cruise will move the throttle to test the actuator and the cable.
Make sure the throttle returns to idle and turn the key off.
Old Apr 1, 2007 | 07:04 PM
dallasstar's Avatar
recall on cruise has been done, even tried bypassing there fuse
Old Apr 1, 2007 | 08:57 PM
projectSHO89's Avatar
Unrelated........
Old Apr 1, 2007 | 09:12 PM
dallasstar's Avatar
Search "clock spring" down in the basement section. ????????
where can i find "basement section" not sure what he means by "basement section"
Old Apr 1, 2007 | 11:24 PM
SSCULLY's Avatar
OK, that is one of the 2 questions.
What happened with the self test listed above ?
Old Apr 2, 2007 | 09:20 PM
dallasstar's Avatar
Everything worked perfect on the self test.
Old Apr 4, 2007 | 10:32 AM
c[[]]'s Avatar
Same prob here
My cruise stopped working a few days agao. 2002 F150. I did the diagnostic thing and it flashes twice at the end. Once for pushing set/accel, once for an error code? What are the codes and what do they mean? Also, can i just call the local dealer and see about getting the switch changed under the warranty? Thanks.
