Cruise control problems...
Old Mar 19, 2007 | 11:45 AM
NeFX4's Avatar
My cruise control decides to work off and on lately- In the morning when I head to work, it works fine, when I leave in the evening to come home- I will try to set the cruise, the light will come on, will work for about 10 seconds, then will go off. Reset it, and the light might flash for a second, hit the set button a bunch more times and the light won't even come on. The next morning, it will work fine again. Any ideas?
Old Mar 19, 2007 | 02:02 PM
SSCULLY's Avatar
Either post the truck info, or complete your profile.
If you have a 03 or older, have you had the cruise control recall done ?
Old Mar 19, 2007 | 02:38 PM
NeFX4's Avatar
sorry, its a 2004 FX4 SuperCab
Old Mar 21, 2007 | 09:36 PM
NeFX4's Avatar
anyone?
Old Mar 22, 2007 | 09:39 AM
projectSHO89's Avatar
There are a number of things it MIGHT be (clockspring, PCM, sensors, switches, etc), however, you'll probably have to take it to a dealer as most of the diagnostics are PCM-based and require specialized tools, training, or documentation.
Sorry, there is no easy-to-run self-test for the 04 and up models like the previous several years had.
Steve
Old Mar 22, 2007 | 11:16 AM
SSCULLY's Avatar
Not like I would ever disagree with Steve, but the '04+ are that much harder to diag then 03 and older MYs.
The 04+ are throttle by wire, no more cable from the pedal t the throttle body on them. This changes how the Cruise Control works greatly.
I would have to go with the herd on this one, and say dealer time.
