What is this connector for?
Old Mar 7, 2007 | 11:06 PM
TexEdition's Avatar
Question What is this connector for?
'05 XLT Screw, there's what appears to be an 8 pin connector mounted directly below the steering wheel. Is this the plug for code readers? Have had this truck since new and never noticed it until today... :o
Old Mar 7, 2007 | 11:14 PM
Klitch's Avatar
i havent looked inide a 04+ truck. i assume thats what it is, OBD II
should be a cover attached to it that even says that
Old Mar 8, 2007 | 01:14 AM
ktexas's Avatar
OBD II connector. I see now your in Austin. Must be a T-Sipper to not know that!
Old Mar 8, 2007 | 01:16 AM
its where you plug in a code reader/scanner and gives up all the trouble codes and what not.... Its all the same connector in just about every car since 96/97 i believe
Old Mar 10, 2007 | 10:58 AM
SSCULLY's Avatar
8 pin connector sounds like the electronic brake controller hook up :
Is this what you found ? :
OBD II plugs are 16 pins not 8.
If the connector is not the one above, is the connector D shaped like an old printer Centronics connector ?
This would be a D shell on it's side, 8 pins on the top row, 8 pins on the bottom row, with a line separating the rows. OBD II ports do not have covers on them ( neither does the E-Brake hook up for that matter ).
