heater
Old Mar 4, 2007 | 03:13 AM
n8sf150's Avatar
heater
i have a 88 f150 and the heater has a problem. it works great but there's only two setting on or off. the heater adjuster doesn't work in between full blast and off. any ideas i already tried putting in another heater switch part behind the ****.
Old Mar 4, 2007 | 07:17 AM
torkum's Avatar
Try the blower motor resistor. I think its located on the front side of the blower motor housing. Better look at a manual, been a while since I have worked on that year. The resistor controls the amount of juice to the blower motor after the setting at the selector is made.
Old Mar 4, 2007 | 11:51 AM
Steve83's Avatar
If everything works except ALL the reduced speeds, then it MUST be the resistor. On all '80-96 with A/C, it's located at the green pointer in the 1st photo below.
Old Mar 4, 2007 | 05:54 PM
n8sf150's Avatar
thanks i'll try the resistor and let you know if it works.
Old Mar 5, 2007 | 05:56 PM
GIJoeCam's Avatar
Yuppers! Resistor pack is shot. Luckily, it's one of the few cheap parts on it... $15 last time I checked.
-Joe
