aux reverse backup lighting.
Old Feb 27, 2007 | 04:39 PM
adrianspeeder's Avatar
Been kickin' the idea of a mod to actually be able to see in reverse at night. Finally gonna get around to it and chronicle it here...
Basicly power comes from a new circuit (be sure to use a fuse), is switched on and off across pins 30 and 87 on the relay, then directly to the new lights.
What triggers the relay is power to pin 86, through the coil, then to ground through pin 85.
Here is how I'm gonna do it. Tapping from the stock reverse wire, whenever the tranny switch sends power to the lights, it will also send power to pin 86 on the relay, switching on the new lights. Also, a toggle switch from a 12v line to pin 86 will trigger the lights on. As a side benefit, the 12v from the new switch also backfeeds the stock lights and turns them on too.
Napa has the relay for 5 bucks and this neat pigtail harness that is color coded which I also labeled on the diagram.
Looky whats on sale now for 10bucks at harbor freight.
http://www.harborfreight.com/cpi/cta...emnumber=47394
Well got over to China Freight today and picked up two. Heatgun also on sale for nine bucks.
Old Feb 27, 2007 | 04:40 PM
I was suprized how heavy they were. Not too cheezy at all.
I'm not to sure on the wiring diagram, I like to put my fuses first. And where can I hire the qualified service tech?
Anyway, this is what I'm thinkin to do under the '88 first. I'll have to be more careful backin' over snow drifts, but I think it'll be purdy safe up there.
Thought it would look cool right on either side of the receiver on the diesel, but that would be hard to hook the safety chains up then. Not too sure 'bout hangin' em way out on either side.
Adrianspeeder
Old Feb 27, 2007 | 06:55 PM
Ok here is just one of these run by a jumpstarter. I think this is gonna work great.
Adrianspeeder
Old Feb 27, 2007 | 09:42 PM
Bluegrass's Avatar
What took you so long?
Been running them for 3 years now.
#10 wire thru a 30 amp fuse at the battery back to the rear relay and switched off the backup lite lead.
I use the same lead to a 4 pin socket to power a light duty wench to pull the sprint car into the trailer without help.
If the battery ever goes dead and locks the doors, I can repower and charge the battery from the rear socket, run small inverter etc..
Old Feb 27, 2007 | 10:26 PM
lees99f150's Avatar
yep, Ive also had them on for a few years now. i prefer smaller the smaller lights though.
Old Feb 28, 2007 | 10:59 AM
sysman_rick's Avatar
Take a look at Whiteknight.com
Old Feb 28, 2007 | 06:55 PM
A vegas casino?
Old Mar 1, 2007 | 05:38 PM
Got 'em wired together with the solder/heatshrink/split tube/tape.
Old Mar 2, 2007 | 07:23 PM
Got em test mounted today, and wired direct to the battery for a light output test. I give it a PASS!
Old Mar 2, 2007 | 07:25 PM
Adrianspeeder
Old Mar 5, 2007 | 05:49 PM
GIJoeCam's Avatar
Originally Posted by adrianspeeder
A vegas casino?
It was a type-o....
http://www.whitenight.com/
-Joe
