Door electricals on 04-06 WTF?!
Old Feb 14, 2007 | 03:44 AM
Kona_Grown's Avatar
Unhappy Door electricals on 04-06 WTF?!
My '05 Screw is having problems with the door electricals. The driver's side window will not go up when I press the button every once in a while(only driver ) and the dome lights will not go on when I open my doors(driver's and driver side rear ). Doe's anyone else have this same problem or similar? Does anyone know what's wrong/how to fix it? Please help, it is so annoying when this happens. Other than that, the truck is in tip-top. Thanks, laters.
Old Feb 14, 2007 | 11:34 AM
umachme's Avatar
It sounds like you need a GEM module. That is the module under the dash on the drivers side in which the fuse panel is attached...
But maybe you should take it to a dealer?
Old Feb 14, 2007 | 05:49 PM
SSCULLY's Avatar
For the dome lamp, is this a case with that door open, the door ajar indicator is not on ?
If so, maybe try some WD-40 on the door latch.
The window, is this recent ? if so have you had some water on your door switches as of late ( i.e. lots of rain, or snow melting on it ) ? If so, the switch itself could be the problem.
