I have a crazy question
Old Feb 12, 2007 | 10:20 PM
Joshuacdrlk1's Avatar
So I have a bagged F 150 crew cab on 22's and I blew an airbag, and layed out hard on my passenger side wirng harness and ripped 2 wire out of the bottom of the harness, the wire have been messed up for a while, and the truck has had a misfire for some time, I am curious if anyone has a schematic for that lower harness cuz I need to move it any way
Old Feb 13, 2007 | 12:44 AM
Bluegrass's Avatar
Well, first tell what year you have.
Your post is a bit hard to follow.
Is it the pass side bag that is blown?
Where is the wiring your talking about.
What DTC codes are present to support the faults?
We need to know as specific as you can make it, to reply with worthwhile comment.
Old Feb 13, 2007 | 12:58 AM
If its any 03-08 truck i can get you a diagram for you, just be more specific on what year/ cab etc
and pics of bagged f150s are always cool
EDIT: i think you are the guy on my friends list on myspace with the silver 01 screw....
so just be more specific what harness you are talking about, and i can get you one for an 03, should be very very similar, if not exactly the same as your 01
Old Feb 13, 2007 | 09:22 PM
it is the actual wiring harness that goes into the firewall my truck runs like *** on sporadiac occasions, and I am wondering if there is something else to look for, my truck is an 01, no trouble codes for that, I have a trans range input high code and a charcoal canister open code, I kinda threw the canister away, I did silicone up the hose and **** so that the fuel pump is not fighting the opening in the gas tank.............. But I have replaced all of the COP's and plugs so I am lost I have a moderate misfire, and you can smell/hear that the truck is running poor ....... It gets like half the mileage it used to...
Old Feb 13, 2007 | 09:53 PM
Bluegrass's Avatar
1. it is the actual wire harness that goes into the firewall! ???????
2. my truck runs like an *** on sporatic occasions! ???????
3. i am wondering if there is something else to look for? !!!! ????????
4. my truck is an 01, no codes for that! ???????
5. I have a transmission range high input! What code is it?
6. charcoal canister open code; I threw it away and siliconed up the hose !!!!
7. and all the other things!!!!
Josh, what's wrong with this picture?
You really think you can be helped much?
Learn how to talk point by point and not run everything togather like jive talk.
I don't think your going to take this very well but your making junk out of the truck if you keep doing things like this.
I won't try to help any further than pointing these things out unless you care to re- consider, then maybe.
Respectfully, good luck with your truck.
