fuse box locction?
Old Feb 3, 2007 | 04:57 PM
Sabonuts's Avatar
fuse box locction?
DEQ couldn't get a connection for their computer to monitor my engine performance - they suggested checking the fuses. #1 - where's the fuse box? Do I have to unscrew a panel under the steering wheel to access? #2 - what else could it be if not the fuse?
......confused in Oregon...and wet.
Old Feb 3, 2007 | 06:09 PM
Bluegrass's Avatar
1. What is DEQ?
2. What year?
3. Are you saying the port dosn't work with a reader device?
4. The system changes to C.A.N. after 03.
Share all this please!
Old Feb 3, 2007 | 09:25 PM
Sabonuts's Avatar
I did find the fuse box on the passenger side... the manual said below the instrument panel and I figured under the steering wheel.....
1. Department of Environmental Quality - they test your vehicle for emissions prior to license renewal.
2. 2006
3. Yep, the port doesn't work according to the inspection guy. He suggested checking the fuses.
Old Feb 4, 2007 | 01:08 AM
Bluegrass's Avatar
Ok. look in your owners manuel at the fuse listings.
Find the one that includes the "Data Link Connector".
It may be included with the cigarette lighter or some other fuse that dosn't affect the running of the truck, if it blows.
Another thing is to look at the pins on the connector for bing pushed back or bent and not able to connect to the inspection equipment.
Old Feb 4, 2007 | 11:13 AM
Sabonuts's Avatar
Thanks Bluegrass. I'll give it a try and let you know how it goes.
Old Feb 4, 2007 | 11:29 AM
SSCULLY's Avatar
I had problems figuring out the location of the fuse panel in my'06 when I got it, the description is really kind of crap.
The fuse panel is located under the right-hand side of the instrument
panel. Remove the trim panel and fuse box cover to access the fuses.
This is the passenger side kick panel, if you have not found it already. There is a figure pull slot, that you pull out.
This is the section of manual, that might help:
https://www.f150online.com/galleries...028-149219.jpg
The fuse you would be looking for is fuse #41, which is also the cigar lighter ( not the 12 V power port to the pass side ).
If the cigar lighter works, then the fuse is good. it is a 20A fuse.
Hope you have something covering your truck when you do this. To read the fuses, you have to lay your head on the pass side floor board, and slide around in front of it. Kind of a PITA.
Old Feb 4, 2007 | 04:09 PM
Sabonuts's Avatar
Thanks for the detailed info SSCULLY. That should help.
Thanks again to everyone for their help. Joining this forum should help a lot.
Old Feb 11, 2007 | 02:05 PM
Sabonuts's Avatar
I was able to locate #41 fuse and replace it and that did the trick.
Thanks for the help guys.
