Dead Battery, Keys Locked Inside!
Old Feb 5, 2007 | 08:40 PM
raisin's Avatar
Well there wasn't any extra charge.........
Old Oct 19, 2012 | 07:27 PM
LucidDev's Avatar
The "through the grill" trick worked great. By the way there is also a power lead from the tow package connector. I realized this while camping and by hooking up the trailer I had enough power to use the keypad to get in. So I didn't need the grill trick after all.
Old Oct 19, 2012 | 08:06 PM
for anyone else looking to post here, this thread is from 2007
Old Oct 19, 2012 | 10:49 PM
SSCULLY's Avatar
Does that mean the info is no good and should be ignored ?
Did the TOU get updated and I missed it, where threads are not allowed to be added to if older than X years ?
Old May 8, 2013 | 11:48 AM
Robodonger's Avatar
Question?
Originally Posted by F150Truck'in
I would try the pos on the starter, not use if these trucks have an ext starter solenoid or not... if it doesn't that wire will go strait to the battery...you can ground anywhere on metal...l:
I saw you gave this answer and I am in the same boat. I have a 2008 F150 and am considering attaching jumper cables to the starter but wanted to make sure it is safe and the right thing to do?
Thanks!
Old Mar 28, 2018 | 11:19 AM
Rob Burns's Avatar
Hey guys, just went through this last night with my 2014 Ford F-150. Reading through some forums, apparently the manual unlock at the door only works if the battery is completely dead. I know it sounds wrong, but too many people found that to be the case, so I assume it is true. Here's the fix used:
Using a long (10" or longer) flat screwdriver, you can manually release the first stage hood restraint through the front grill. It is not an obvious thing to see, so I took a good picture of it this morning and will post it here. Essentially, there is a lever attached to the release cable coming from the truck interior that can be moved to disengage the latch. It is actually behind the main latch assembly at the bottom, but you CAN access it (not easy to see though). You need to use the screwdriver to move the lever to the right (toward driver side) an dthe latch will disengage. Then you can get a boost from another car or portable charger to allow the door locks to open, and of course start the truck. In the attached pic, the latch is shown as #1, and the direction you have to move it is #2.
Old Mar 28, 2018 | 12:42 PM
That's a good suggestion.
I've done this before for others.
Old Mar 6, 2020 | 12:43 PM
Angela Cruise's Avatar
​​​​​​That helped me out so much with the picture. Because after I seen what u were talking about i found it so easy. Thank you so much
Old Jun 13, 2021 | 08:58 PM
An Brock's Avatar
Thank you
I bought a slim Jim but no luck then I searched Google found this thread and the picture and detailed description is worth a million bucks thank you!! Hood popped, heading to Auto Zone now to get the battery tested thanks again.
Old Jun 21, 2021 | 12:56 AM
1MoreFord's Avatar
In the future put a road service rider on your insurance policy. It's dirt cheap on State Farm and covers a bunch of problems.
