Can you believe another battery light?
Old Jan 25, 2007 | 09:48 AM
ckoerner's Avatar
I read all the posts on battery lights. Bunch of them. Except my problem is that mine does it at first start up and then goes off when I bring the rpm's up. Then it will stay off. With the light on my voltage is 11.8. When it goes off it goes back up to 14.3-14.5v. Once it went off I turned everything electrical on including the stereo system that draws some good current. Voltage stayed between 14.3 and 14.5. Just thought I would post because almost everyone elses comes on at high rpm's.
Unless I'm missing something I will do as Yankee7985 suggests. "Replace the alternator"
Old Jan 25, 2007 | 09:27 PM
ckoerner's Avatar
Changed the alternator. Works fine now except for an idle problem now. If it aint one thing it's another.
Old Jan 25, 2007 | 11:24 PM
Bluegrass's Avatar
You got your answer in the engines section.
Old Jan 26, 2007 | 09:36 AM
ckoerner's Avatar
Thanks!
