cruise control
Old Jan 12, 2007 | 08:05 PM
ducati648's Avatar
Exclamation cruise control
I'm having a problem with my f-250's cruise control, its a 2001 but i'm sure the cruise control and everything is the same as on the f-150s which is why i was hoping someone could help me. The cruise control only intermittently works and at the times that it doesn't work, i can see the little like that says "cruise" come on and then shut off again really quickly in the instrument cluster, i was wondering if anyone had any ideas as to what could be causing this. Thankyou!
Old Jan 14, 2007 | 09:42 PM
way fast witey's Avatar
i would take it to a dealership and have them run the vin to see if it has a recall like the 150's and i wouldn't use it til then cause the 150's could catch on fire (hence the recall) just to be on the safe side.i had mine fixed at the dealership,took about 30 minutes.they changed the fitting on the brake fluid reservoir for the cruise cut off switch and added a longer pigtail to the switch.but now mine's quit workin again.it had quit workin before i took it in for the recall
Old Sep 22, 2011 | 10:36 PM
kd5csd's Avatar
got a 2001 f150 4.6 supercab the cruise just quit working . Does anyone have idea or advice about this problem.
Old Sep 22, 2011 | 11:58 PM
SSCULLY's Avatar
did you have recall 05S28. ( Speed Control Deactivation Switch ) completed ?
If so it could be a blown fuse in the recall harness.
Check the switch to see if it is leaking fluid, if so, chances are the fuse in the harness is blown.
Try the Cruise control self test, prior to unhooking the recall harness, to see if it is functioning.
If the self test does not complete, unplug the recall harness and jumper the end of it ( do not plug into the switch on the braking system ), and re run the self test.
Self-Test Diagnostics
WARNING:
This test is a key on engine off (KOEO) test only that is conducted in park only with emergency brake fully engaged.
1. Enter self-test diagnostics by depressing the speed control OFF switch while turning the ignition key ON, making sure the engine does not start and is not running. The speed control indicator on the instrument panel will flash once to indicate that speed control module entered the diagnostic mode. Five additional flashes at this point indicate a defective speed control servo. Release the OFF switch.
2. Press the remaining switches in this sequence: ON, RESUME, COAST and SET/ACCEL.
If the ON switch is not depressed within five seconds after entering the diagnostics mode, the module times out and the procedure must be started over.
The speed control indicator lamp will flash as each switch is depressed. Press each switch in the sequence immediately after the indicator light goes out for the previous switch.
Note:
There will be a slight delay when the last button is pressed and the lamp flashes.
3. A lamp flash with the last button (SET/ACCEL) indicates that the static test passed. If the lamp does not flash with the last button and there are no additional flashes of the lamp, the switch is defective.
If the lamp does not flash with the last button, and additional flashes occur, follow the chart below for trouble codes:
— 2 flashes - BPP defective, circuit is defective, brake applied, CPP switch or jumper (if equipped).
— 3 flashes - deactivator switch is open or circuit defective.
— 4 flashes - vehicle speed signal is out of range or circuit is defective
4. Immediately (.25 second delay) after the static test, the speed control servo does a dynamic test by automatically actuating the throttle lever from 8 mm (0.315 in) to 12 mm (0.472 in) of travel from the idle position. During the dynamic throttle pull, observe throttle movement to witness any binding or sticking of the speed control cable and correct connection of speed control cable to throttle lever. Make sure the throttle returns to the idle position.
5. Return the ignition switch to the OFF position and proceed to the Symptom Chart.
