unpuckled seatbult sensor disconnection
Old Jan 10, 2007 | 07:41 PM
steelshot220's Avatar
Exclamation unpuckled seatbult sensor disconnection
IS THERE ANYWAY TO TURN OFF THAT ANOYING *** FASTEN SEAT BELT SENSOR( YOU KNOW THE ONE THAT BEEPES WHEN YOU DONT HAVE IT ON)
CAN I CUT A WIRE OF SOMETHIN CASUE I WORK ON A FARM IN THIS TRUCK (2004 F150 XLT SUPCAB 4x4) AND I CANT HAVE MY SEAT BULT ON DRIVING AROUND THE FEILDS
PLEASE HELP ME
THANKS
Old Jan 10, 2007 | 08:24 PM
ian51279's Avatar
Check your owner's manual.
Old Jan 10, 2007 | 08:54 PM
hawkfxr724's Avatar
what year/model?
I was able to turn off my seatbelt dinger by following the steps in my owners manual. Depending on what year/model your truck you have. If you don't have your manual, I can send you the steps.
Best of luck,.
DC
Old Jan 10, 2007 | 08:57 PM
Best of luck,.
DC
ya can you send me the step thanks mannnn its a 2004 f150 supcab xlt
Old Jan 10, 2007 | 09:34 PM
nigdonht's Avatar
It's on page 117-118 of your owners manual, but here's what it says:
Deactivating/activating the BeltMinder feature
The driver and front passenger BeltMinder are
deactivated/activated independently. When deactivating/activating
one seating position, do not buckle the other position as this will
terminate the process.
Read steps 1 - 4 thoroughly before proceeding with the
deactivation/activation programming procedure.
The driver and front passenger BeltMinder features can be
deactivated/activated by performing the following procedure:
Before following the procedure, make sure that:
• The parking brake is set
• The gearshift is in P (Park) (automatic transmission)
• The ignition switch is in the OFF position
• The driver and front passenger safety belts are unbuckled
1. Turn the ignition switch to the RUN (or ON) position. (DO NOT
START THE ENGINE)
2. Wait until the safety belt warning light turns off. (Approximately 1
minute)
• Step 3 must be completed within 50 seconds after the safety belt
3. For the seating position being disabled, buckle then unbuckle the
safety belt 9 times, ending in the unbuckled state. (Step 3 must be
completed within 50 seconds after the safety belt warning light turns
off.)
• After step 3, the restraint system warning light (airbag light) will be
turned on for three seconds.
4. Within 10 seconds of the light turning on, buckle then unbuckle the
safety belt.
• This will disable the BeltMinder feature for that seating position if it is
currently enabled. As confirmation, the restraint system warning light
will flash 4 times per second for 3 seconds.
• This will enable the BeltMinder feature for that seating position if it is
currently disabled. As confirmation, the restraint system warning light
will flash 4 times per second for 3 seconds, followed by 3 seconds with
the light off, then followed by the restraint system warning light
flashing 4 times per second for 3 seconds again.
And if you've lost your manual, and want to print one out, you can go here:
https://www.fleet.ford.com/maintenan...ls/default.asp
Old Jan 10, 2007 | 09:36 PM
ADDIFUSION's Avatar
yea just turned off both the driver and the passenger seat off, by following my manual.
it's pretty easy, and now I don't have that annoying sound
Old Jan 11, 2007 | 08:17 AM
GIJoeCam's Avatar
Doesn't anyone ever read the manual anymore? It's amazing how many answers can be found in there!
:rolleyes
-Joe
Old Jan 11, 2007 | 11:46 AM
2stroked's Avatar
:rolleyes
-Joe
Check the spelling (or lack thereof) in the original post. Based on that, I'm not sure reading is a strong point.
