Headlights Inop
Old Jan 5, 2007 | 10:37 PM
keepkool's Avatar
Headlights Inop
Just picked up my 2007 f150 crew cab on 1-2-07. autostart was installed on 1-4 . everything worked on pickup but now no Headlights (Low or high). running lights and fog lights work fine. anyone have any Ideas where to start. thansk all. kevin
Old Jan 5, 2007 | 11:12 PM
bullseye670's Avatar
Originally Posted by keepkool
Just picked up my 2007 f150 crew cab on 1-2-07. autostart was installed on 2-4-07. everything worked on pickup but now no Headlights (Low or high). running lights and fog lights work fine. anyone have any Ideas where to start. thansk all. kevin
Sounds like they aren't going in till next month! 2-4-07
sorry, I couldn't resist!
Old Jan 5, 2007 | 11:40 PM
SSCULLY's Avatar
Maybe check the fuses first.
If they are good, next would be to see if you have power at the headlamp bulb connector with a volt meter.
If neither of these are it, then going to need some additional info I did not see in your profile ( hope I did not miss it in the signature area ).
Trim Level ( XL - XLT, Lariat, etc ).
Do you have Autolamps ( might be answered depending on the trim level, if not is can be an option ).
Do you have DRL ( Day time Running lamps ) ?
Those are the first places to start.
I take it you don't want the dealer to play with it again, thus why you are working on a '07 that is only 4 days old ( and I took the 2-4-07 to be a typo of 1-4-07 ).
Old Jan 6, 2007 | 05:35 PM
keepkool's Avatar
all better
sorry for the type-o earlier. Truck lighting is repaired. wiring harness pin not clicked in all the way. will have some pics up later. thanks kevin
