Two problems...
Old Jan 4, 2007 | 08:02 PM
techspecial's Avatar
Smile Two problems...
Neither of the mirrors on my 2000 F150 will move...I'm assuming it's a blown fuse. Which fuse is it? I also need to replace the door lock actuator on the passenger side. What is the procedure after the door panel has been removed?
Thank You All Very Much!!
Old Jan 4, 2007 | 08:35 PM
SSCULLY's Avatar
1. Fuse location : Owners Manual page 132, shows pass compartment fuse panel fuse 5 AMP in location #4.
If you don't have an owners manual, you can download one :
http://www.fleet.ford.com/maintenanc...ls/default.asp
http://www.genuineservice.com/genuin...ault?page=Home
www.motorcraftservice.com/
2. door lock actuator -> try a search on the term : door lock actuator and the results are 138 threads.
2 of note ( the others might be of interest to you also ) :
https://www.f150online.com/forums/sh...+lock+actuator
This one has an external URL, which shows what you seem to be asking about :
