Running lights
Old Jan 4, 2007 | 12:13 AM
my2000F1507700's Avatar
Thumbs up Running lights
Can anybody tell me. If I install running lights can i hook them up to my light switch and not on a seperate switch THANKS
Old Jan 4, 2007 | 09:16 AM
SSCULLY's Avatar
Can you describe the running lights ?
To me it can be considered 2 things, and I don't want to make an assumption.
1. Additional Fog / driving lamps ( in addition to the factory fog lamps )
2. Additional parking lamps, as in along the roof of the cab, or along the running boards ( if installed ).
Those are the 2 things that I take running lights to be.
Any spec's on them ( manufacture, model number, AMP draw, etc ) would also help.
Old Jan 4, 2007 | 09:27 AM
jmt0645's Avatar
yes you can, simply remove the light switch and tap the brown wire on the top left of the switch. I had to do the same to wire the clearance lights on my mirrors, 7 months with no issues. In fact my dealer said the mirrors look like they were installed by a pro.
Old Jan 4, 2007 | 09:30 AM
running lights
Sorry for the confusion the running lights are for the roof. They are Fords super duty Hi five oe style 12 volt 3.5 amps thanks
Old Jan 4, 2007 | 10:11 AM
SSCULLY's Avatar
jmt0645 gave you the correct place to tap them.
Ford does the same thing on the SuperDuty line from the factory ( actually with a splice in the kick panel ) to power them.
Few members on here have added the clearance lamps to the top, maybe try a search on running lights / running lamps, clearnace lamps, roof lights to find the posts ( can't recall when I saw them, maybe 10 + months ago ). Just a thought, if you want some additional threads on the topic.
Old Jan 4, 2007 | 10:18 AM
Thumbs up running lights
Thanks for the help everyone:
