Service engine light on
Old Dec 16, 2006 | 02:18 PM
Jeff Thomas's Avatar
My 01 F150's sevice engine light came on, so I went to Autozone to have it code scanned, it said engine bank lean, so I replace the air filter, it was nasty. Now how do I reset the light to see if that was the problem. BTW, the truck has less that 75K on it, so I am trying the small stuff before I start on the sensors.
Old Dec 17, 2006 | 12:32 AM
projectSHO89's Avatar
use the exact fault code(s) as your SEARCH argument.
You'll probaboy find helpful advice.
Old Dec 17, 2006 | 09:12 AM
mneal's Avatar
Disconnect the battery and turn headlamps on, that will reset the code. The clogged air filter should have made it too rich, not lean though so I expect the code will return....look for vacuum leaks.
