sticking gas guage (2000 F150)
I have seen this problem on the forums before, but I have not seen a solution yet. The guage spends most of the time on empty or full , some times it will register in between. I have replaced the sending unit in the tank. Anybody heard of a fix?
togojc
togojc
2005 F150 SuperCrew Lariat
after fueling the gas gauge stayed on empty and the estimated miles to travel stayed on zero. Went back to the gas station to be sure their pump wasn't in error. It wasn't. Went to nearby ford garage, they verified our fuel tank was full. Continued our trip, gauge slowly returned to correct reading (full) This was really crazy.
togojc
togojc
You could try this: pull the board off the back, clean the pins and sockets with contact cleaner and/or a pencil eraser, and re-assemble. Look for the "intermittent odometer fix" thread for cluster R&R and pics.
Mine did the same the other day. After a full tank, it still read 1/8 tank. I figured that the -12* temp was to blame. Put the truck in the garage that night and the next day it read Full.
I'm guessing it froze in that position.
