Wiper switch install
Old Dec 7, 2006 | 08:30 AM
sparkyrhett's Avatar
I am attempting to remove/install this wiper switch assembly in my 1991 F150. (Please see fig 1). I am somewhat of a clutz, so if anyone could give me a bit of advice I would certainly appreciate it. First, how would you remove the ****, (Please see fig 2). I can not find a clip or screw of any sort. Am I supposed to just pull it off? Next, how do they expect you to get behind all this mess (Please see fig 3) and chase the proper wires to unplug and replug etc. I can barely get my hand in there to unplug/plug anything. It looks like I may be able to drop the fuse box to make more room. Is that adviseable? I have tried to find a way to remove the lower dash panel/bezel on the left side of the steering column to provide better access, but can find no way to remove it without breaking it. Is it clipped on somehow?. I believe that there are screws that hold the switch in place behind the dash, but I think they are accessable behind the bezel. Help!!!! I have included photos to help explain. Thank you
http://i144.photobucket.com/albums/r...rhett/Fig1.jpg
http://i144.photobucket.com/albums/r...rhett/Fig2.jpg
http://i144.photobucket.com/albums/r...rhett/Fig3.jpg
Old Dec 8, 2006 | 12:48 AM
Steve83's Avatar
If you put those image URLs inside [img] tags, the pictures will appear in your post, like this:
Read the BBS FAQ about UBB code usage, or look for a "HELP with UBB Code" link on the regular ADD REPLY page. But the easiest way is to copy the URL into your computer's ClipBoard memory, then click the IMAGE icon (yellow square with mountain & sun), then paste it into the dialogue window & hit ENTER.
__________________________________________________ ___________
If you look at the base of the **** where the shaft goes in, you can find a notch. Use a small screwdriver or pick to push the thin metal tab rearward (away from the dash) & the **** will slide off. The headlight **** is similar.
Remove the knee bolster first, and you should see the screws for the lower dash panels. They also have clips, so once the screws are out, you still have to pop them loose.
Why are you trying to change the wiper switch? You already have interval wipers, and they rarely go bad.
