PIAA 1000x Platinum in fog lights ??????
Old Dec 5, 2006 | 01:59 AM
DTheobald's Avatar
PIAA 1000X Platinum
Can these go in my fog lights?
Old Dec 5, 2006 | 10:07 PM
ian51279's Avatar
These can't go "IN" your foglights. Are you looking to replace the whole foglight assembly or just brighter bulbs? You could remove your factory lights and fab some sort of mount for these lights.
Old Dec 6, 2006 | 01:16 AM
DTheobald's Avatar
There is a member on this forum that has hid lights i think in his fog lights... I just want brighter and maybe a tiny tint of blue... what are xenon lights, are they the ones that have the sharp cut off??? would those piaa lights mount to a bull bar if I got one??
Old Dec 6, 2006 | 02:53 AM
crashtheline's Avatar
Ok...that cutoff line is created by a special bulb housing called a "projector".
If you want HID in your foglamps, buy and HID kit with the same bulb type as your fogs. It is the Bulb and everything needed to be HD. If you want a blue tint go with the 6000K system.
Xenon bulbs are just replacement bulbs with a different gas inside to burn whiter.
Old Dec 6, 2006 | 07:38 PM
flareside4life's Avatar
I would think about the color choice for your light bulbs. If you actually get dense fog where you live, really bright white lights will reduce your visibility even when their pointed at the ground. I replaced my standard fog light bulbs with the PIAA yellow replcaement bulbs and there was a huge difference in visibilty.
