Need help with turn signal
Old Dec 2, 2006 | 06:51 PM
Budman1962's Avatar
The turn signals on my 97 f150 stays on constant. It doesn't flash at all. I took the multi function switch apart and cleaned the green goo with electronic cleaner and a scotch brite pad. Didn't help at all. Then I bought a flasher at napa. I put it in and it didn't help. Then I noticed the little box that is right next to the flasher unit. If I tap it with something the flasher works for a second. What is this box. I tried to pull it out like the flasher but it doesn't come out. Any help would be awsome.
Budman
Old Dec 5, 2006 | 10:07 PM
Budman1962's Avatar
Does anyone know if there are two flashers on a 97 f150. The emergency flashers work fine.
Budman
Old Dec 6, 2006 | 11:53 AM
SSCULLY's Avatar
Single flasher on the '99 ( the only EVTM I have access to right now ), so I woudl suspect the same for the '97 ( not that much changed, usually ).
The relay next to the flash is not for the flashers themselves. I am trying to find the post on this topic.
Looks something like this :
Old Dec 6, 2006 | 12:07 PM
SSCULLY's Avatar
Found it :
https://www.f150online.com/forums/sh...ghlight=158802
The other should be the blower motor relay. Maybe a bad ground from the flasher / blower motor relay block ?
I would think both fo these go to a common ground point, but I do not have the EVTM for the '97 MY to confirm.
Old Dec 6, 2006 | 02:23 PM
Budman1962's Avatar
Thanks for the info. I thought there was two flashers because The emergency flashers work fine but when I try the turn signals they just come on and don't flash. All the bulbs are fine. maybe the flasher I bought is bad. I'll keep looking. I hate taking it to a dealer for $57.00 per hour.
Thanks,
Budman
Old Dec 7, 2006 | 06:21 AM
SSCULLY's Avatar
Originally Posted by Budman1962
...<snip>...The emergency flashers work fine but when I try the turn signals they just come on and don't flash....<snip>...
This is usually a symptom of a bad MFS. I saw were you posted that you cleaned it, but something could still be up with it. Did you check the pins in the connector while you had it out ?
