Possible battery problem
Old Nov 15, 2006 | 08:37 PM
Reloader's Avatar
Hi guys.
Yesterday morning, starting the truck to go to work, all my gages did the sweep to the right for about a second, then returned to normal. When I got off work, the same thing happened. Today, everything acted normal, no gage sweep. I know this says that the battery might be getting weak, or already is, so I decided that this weekend I would replace the battery before it fails in an inopportune time and place. This appears to be the original battery, and I was thinking of going to my local Pep Boys to pick up a red top Ultima.
Do you think I should do this, or have I answered my own question?
I just want to hear what you guys think and would do in this situation.
Thanks for your input.
Old Nov 15, 2006 | 09:31 PM
Ultra_Miner's Avatar
yep most likely the battery. Mine did the same thing, ended up being a weak battery.
Old Nov 16, 2006 | 05:32 PM
chiefFX4's Avatar
you will notice a difference with the red top. optima makes a great battery. id replace with that just because of the reliability.
Old Nov 16, 2006 | 11:35 PM
JMC's Avatar
JMC
25 Year Member
Get the battery tested. It is free. If that is the problem then change it. If it is not then you didn't blow $$$$ for a battery. Optima makes a good battery but if you don't need the gel type you can save money by purchasing a conventional one. Get one that meets the CCA for your vehicle. I would choose one with the minimum required CCA but the highest reserve capacity. A higher reserve will allow it to crank for a longer period. That is what will get you going on cold mornings when oil turns to syrup.
JMC
