1998 5.4L Negative Battery Cable Replacement
Greetings,
I'm in the process of replacing my cracked and green negative cable and after doing a search here, I discovered some owners attaching the new negative cables to their alternator brackets. Is this in lieu of the starter cable attachment to the frame ground?
I found various prices on the replacement cables from $35>$64 and want to research this before I pull the trigger.
What are my options Guys?
Thanks.
Charlie. (The guy that used to know what he was doing when he had an L82 to work on)
Thanks.
