question about getting new spot lights.
Originally Posted by SCREWKR
how brite should the spot lights in the grill be?
As far as I'm concerned, the best bang for the buck is a set of sealed-beam 150-watt (385,000 candlepower) KC Daylighters. From www.desertrat.com, $79 for chrome or black, $99 for stainless. I've got 'em on my F150 and my Explorer. They're about as bright as you can get without going to either HIDs or some ungodly expensive lights like LiteForce.
-Joe
Yes, behind the grill works just fine. I have a set of Hella 550s with 130 watt bulbs. Just make sure you wire that kind of fire power correctly. There's a ton of current draw so correct wire sizing and a relay are required. More pictures in my gallery.
Another Fog Light option.
Another fog/spot light option. Costs less than $100 total and easy to do if you are handy at all. I will have pictures when I have completed this install (my second). These lights will be behind the grill also.
https://www.f150online.com/forums/sh...d.php?t=258963
PlainJane150
PlainJane150
I have a set of Eagle Eye purchased from J.C. Whitney 100 watts each on my bull bar and the work great for under 50.00 dollars
Thanks for all the replys fellas, I went with 4 hella 100 wattrs behind the grille. As to anwser the question from before im am in a 2002 supercrew king ranch 4x4. I got the lights put in and the my new flowmaster 50's put on I decided to run dumps so I hope it sounds good but the guy puting it all in wanted to know who i wanted to blind hopefully it will be bright enough to light up the MUD! lol It will be good times.
