Dash Cluster Removal
Really easy, pull the piece that sits over the column out by gripping the top and pulling a bit. Then, unbolt as many screws you see around the cluster, there is one behind the light switch too. Have a magnet handy as some screws are hard to take out or reinstall without dropping, trust me. It's hard to say everything because things like removing the gear selector are hard to explain. You have to find a way to remove the body of it away from the cluster itself. Do a search on here about the odometer (digital) fix and a guy explains in great detail. Once you do it, you'll be pro.
