Fog Lamps
Originally Posted by ADDIFUSION
so I just bougght a 06 F150 XLT, beutiful if you ask me
and I was wondering is there way I can add the fog lamps?
and if so, where can I get those at? any good places?
Guess it would depend on how you would want to mount those fog lights. You can add a brush/grille guard, mount them behind the grille, etc. Don't know if you can install them in bumper. You can purchase aftermarket fog lights or you can purchase factory lights. (If available for you rig). I have KC lights on my rig mounted on a knockdown grille guard from Go Industries.
Post some pics of your rig
Mike
on
A few have changed / added the stock fog lamps.
Thing is, for stock fog lamps, you would need to order a new bumper, bumper bracket, and change out the headlamp switch Then it is time to check for wiring ( which may or may not be installed ).
If you are looking to add the stock fogs, start with looking up under the bumper to see if the connectors are there, prior to getting parts ordered.
I can't recall the last member that tried this, had no luck with a STX I think.
If you are looking for aftermarket, there are several options ( in the bumper spacing, behind the grille, on a prerunner bar etc.
Let us know which way you were looking to go ( factory or after market ) so we can get you some good advice to look into.
