dome light does not come on with unlock or fade out
I had the sticky door sensor and wd 40 worked. The light goes out. However, the dome light no longer comes on with the remote unlock nor does it fade out when I close the door, It does come on when I open the door and goes out when I close it so it is not a major problem but I like having the light come on when I unlock the door and stay on briefly when I close it. Is there a timer somewhere that controls this function. I haven't tried the radio but the windows do not delay either.
I have a 98 so warranty won't help. I have tried pulling the fuses and relays to no avail and, as all the lights work except for the delay it is not the door sensor. The windows do stay on for a bit after the key is off but the radio does not. The dealer says it is the GEM and wants $400+ to replace it but can't guarantee that will fix it. I have been told that removing power from the GEM may reset it so I think I will disconnect the battery and try again.
Thanks for the replies
