Battery light on...
Old Oct 3, 2006 | 07:55 PM
Rotties150's Avatar
Battery light on...
((also posted in Engines forum...might get better response here?!))
Battery light started to flicker this morning. The owners manual says that the battery may not be charging correctly.
Is this the battery itself not holding a charge and should it be replaced? It is about 6 yrs old. Sears "Gold" if that means anything.
-or-
Is it the alternator? How do I tell if the alternator is charging properly and if it needs to be replaced?
As always, any help is always greatly appreciated...Scott
Old Oct 4, 2006 | 10:12 PM
Yankee7985's Avatar
Most likely your altewrnator going bad. The brushes are most likely worn and are not making full contact at all times, which causes the battery light to illuminate.
Old Oct 5, 2006 | 10:10 AM
ws6_guyscrew's Avatar
yep, replace the alternator now before it starts draining your battery!
