Help with O2 sensor problem.
Old Oct 1, 2006 | 08:10 PM
ckoerner's Avatar
I was getting P-0133. Slow responce from oxygen sensor. I had the O2 sensor replaced and still get the same code. Any other ideas. They told me it's usually the catalytic converter. They want $500.00 to replace the converter. I hate to just start replacing things. The thing that sucks is I have to go through emissions testing this month.
Thanks,
Craig
Old Oct 2, 2006 | 02:34 AM
SSCULLY's Avatar
Got any specs on the truck ( your profile is empty ).
Engine size.
MY
Trim level just in case there is a wiring difference.
Cab type.
PS : Fill out your profile, so next time the info is available straight away.
Old Oct 2, 2006 | 09:03 AM
ckoerner's Avatar
Done. It's a 2000 5.4 2wd XLT Supercab.
Old Oct 2, 2006 | 09:13 AM
brandonhadnot's Avatar
which o2 sensor which bank was it bank 1 or 2
Old Oct 2, 2006 | 09:14 AM
projectSHO89's Avatar
It ain't the coverter. The cat cannot cause this code.
Assuming they replaced the correct (Upstream, passenger side) side, you'r left with a possible vacuum leak or an exhaust/manifold leak that is specific to bank 1 only.
If this was an independent shop that did the previous, I'd suggest taking to a Ford dealership that has a good diagnostic technician who actually understands the systemand has the proper tools and test procedures to diagnose and repair it properly.
Steve
Old Oct 2, 2006 | 09:16 AM
ckoerner's Avatar
I'm sorry I am getting P-1331 code now.
Old Oct 2, 2006 | 09:21 AM
P-0133 is bank 1 sensor 1 which is the front o2 sensor on the drivers side.. you replaced the wrong one if you already replaced one
Old Oct 2, 2006 | 09:27 AM
hang on i have a list of all codes let me boot it up
Old Oct 2, 2006 | 09:43 AM
ckoerner's Avatar
I was getting P-0133 and i was told it's the passenger side one. So that was replaced. Now I am getting P-1131.
Old Oct 2, 2006 | 09:44 AM
ckoerner's Avatar
I also read this http://autotechrepair.suite101.com/a...r_flow_sensors
Old Oct 2, 2006 | 09:48 AM
its on the drivers side... i know what im talking bout
Old Oct 2, 2006 | 10:22 AM
ckoerner's Avatar
I am not trying to argue or anything, but all the searches here say bank 1 is the passenger side.
Old Oct 2, 2006 | 10:33 AM
after looking at this diagram i got... turns out i was wrong.. your right its on passenger side... but which did you replace... the front or back... the each are different ones heated and ones not...
Old Oct 2, 2006 | 10:49 AM
ckoerner's Avatar
I replaced the front one.
Old Oct 2, 2006 | 10:52 AM
if you still gettin a o2 code on the passenger side your back one has gone bad also.. replace it to... me i just replacedall 4 of mine at once so i didnt have hunt anything with a good buddy working at partstore and a cousin working for ford i get one hell of a discount so it just money ... spend it
