check engine light on
Old Aug 22, 2006 | 02:27 AM
firemannelson37's Avatar
My light has been on for a long time now. I got the edge evo and checked it. It came up with 2 codes, here is what they said. P1000-OBD 2 MONITOR,CHECKS NOT COMPLETE MORE DRIVING REQUIRED. Here is the other. P0102-MASS AIR FLOW CIRCUIT LOW INPUT. Could someone please tell me what they mean? Thank you
Old Aug 22, 2006 | 03:19 AM
ncsufire's Avatar
I found this website that might be helpful - http://www.obd-codes.com
P0102
P1000
Looks like the P1000 is caused by the P0102! Hope this helps.
Old Aug 22, 2006 | 09:56 AM
projectSHO89's Avatar
Worry about the P0102 only. The P1000 will clear itself eventually when all other issues are corrected.
P0102 is likely to be due to a fault in the wiring to the MAF sensor, the sensor itself, or the PCM. There is a specific step-by-step diagnostic procedure in the service manual to pinpoint the fault.
Steve
Old Aug 23, 2006 | 02:25 PM
thanks for your input, i will try cleaning the MAS.
Old Aug 23, 2006 | 09:45 PM
ncsufire's Avatar
OOps I got the link wrong above, I have fixed them.
Old Aug 25, 2006 | 04:30 AM
I did some searching and found that the wire wasnt connected, and thats all the problem was. Thanks for all your help anyway.
