1999 F-150 Speedo Question
Old Aug 20, 2006 | 05:51 PM
54F100's Avatar
Hello,
I'm working on a highly modified (Damn thing) 1999 F-150
The original idea was to run aftermarket gauges, so the thought of running the stock setup was not in the inital build thought process. So now, I'm stuck with trying to run the factory speedo with a hardly stock trans and ABS setup.
My question is (from what I've read) does the rear ABS speed sensor run the computer speed output thus running the speedo, cruise, and rear ABS? The truck originally had 4WABS, not now...
Also, the wires for the rear sensor are not where they should be... Does anyone know what the wire colors are for the sensor, I'm going to have to get a pigtail and find the wires where they were removed/cut.
HELP
Also, here is some videos of the project,
http://www.trawets.com/ChadsTruck/
If FORD won't build a super truck... I guess I will!
