88 f250 electrical issues!!
Old Aug 4, 2006 | 06:55 PM
rdakrt's Avatar
Alright guys I really need some help here. 88 f250, 5.8 L, auto trans. I have constant power to the starter and it just keeps crankin over until I disconnect the battery. Now I can't even connect the battery without fireworks and cranking. Replaced battery, cables (including new ground and cleaned connections), starter, starter solenoid. Now the weird part. I have constant power to the red trigger wire going to the solenoid without the key being on. The weird thing is if I disconnect the wire that goes from the solenoid to the starter at the solenoid end I have 12 volts from that wire but no power at the starter end. Am I just tired, or crazy? Could it be the new starter? Please help.
Old Aug 4, 2006 | 07:24 PM
subford's Avatar
No its not the starter, the Red wire (rigger wire) should not have power on it unless the Ignition switch is in the start mode.
You have a bad Ignition Switch or the operating hardware for the switch.
Old Aug 4, 2006 | 08:04 PM
rdakrt's Avatar
Ok so I was searching the posts and found another one similar. I switched the wires on the solenoid eventhough i hooked the new one up the same way I took it off and the truck cranks but now I have no fuel pump which is the problem I started with a long time ago. I replaced the fuel pump relay and the fuel pump before this and it worked fine until now. Then I went to start it again and it just kept cranking and had to pull the neg. battery terminal....AHHHHH! This truck is going to drive me nuts.
Old Aug 4, 2006 | 09:17 PM
subford's Avatar
Sounds like you put the Fuse Links on the wrong side of the solenoid.
