Rear Driver Side Window? Help.
Old Apr 5, 2006 | 11:58 PM
turybnice's Avatar
HI everyone need some help here my window stop working the motor is fine so is switch.I removed door panel and found this cable was loose I tried to put around pulley at top right down to window frame .to pull up didnt happen I end up with other end of cable came out of motor.everything still work's I was wondering if anyone know's or pic's of how to install the cable's thank's here a pic. of the cable that came loose.
Old Apr 7, 2006 | 09:03 AM
turybnice's Avatar
hello anyone.
Old Apr 9, 2006 | 11:02 PM
dwsf150's Avatar
If the cable is off the pulley then it is time for a new window regulator. I've put in quite a few. You'll need a 1/4" rivet gun to attach the glass to the regulator, may be worth taking it in.
Old Apr 9, 2006 | 11:55 PM
Quintin's Avatar
The regulator's broken. Happened to the left front in my truck a few months ago.
