Keyless Entry 2004 1/2 Supercrew (New Body)
Old Dec 3, 2009 | 10:06 AM
SSCULLY's Avatar
Sounds like you are trying to use the 5 digit code from the stick on keypad, where the one in the door needs the factory code from the BSM/VSM behind the rear seat back on the SuperCrew.
Take a look in the Technical Articles for a How to on removing the seat back. You will then need to remove the trim panel that is on the back wall, and get to the VSM. There is a sticker on it, with the 5 digit factory code.
You can then add the personal code ( following the directions in the owners manual ) to set it to the code you were using the on the wireless keypad.
Old Dec 3, 2009 | 10:14 AM
Yes, if you had the stick on, it does not function like the keyless door handle pad. It is actually using the same frequency as your key fob. In other words, it's a key fob that requires a code rather than one button. That code will not be the factory code for the keyless entry. Here is what I went through. you may find also, even if you have the factory code that your BCM has to be programmed.
https://www.f150online.com/forums/20...dded-help.html
Old Dec 3, 2009 | 10:54 AM
SSCULLY's Avatar
...<snip>.... Here is what I went through. you may find also, even if you have the factory code that your BCM has to be programmed.
From what I read in your thread, you could not get lights, don't know if you ever tested the 7/8 & 9/0 combo to get the ( search for 7 only showed up in post counts, times, and the 172 cost for the VSM ). You did have the problem with the alarm being set off when you pressed a button ( no lights on the buttons ).
Old Dec 3, 2009 | 11:14 AM
GeronC's Avatar
yes, sorry. i should have said that. My stick on wireless one, works whenever it wants to, but the wired one, will only lock, not unlock.
Old Dec 3, 2009 | 11:18 AM
Ok, what you need is the code for your keyless entry, that was put in from the factory. It is 5 digit and you can get it off a label that is behind the back of the rear seat, or you can go to the dealer and they can retrieve it with a program. That code never changes and you have to have it to ebter your own selected code. The unit will then have 2 different codes and both will work. Any time you change your selected code, you have to enter the factory code.
Old Dec 3, 2009 | 11:34 AM
GeronC's Avatar
is it not the same code that is on the credit card size piece of paper in the manual? I guess that is the one that came with the wireless stick on. I'll pull the seat out and find it.
Old Dec 3, 2009 | 11:50 AM
You may have the right card in the manual, if so, it will be from Ford. If it is not from Ford, I bet someone wrote it on a card when they put the stickon on. The stick on will not use the same code as the keyless handle. It's possible you have the same problem I had, there was a ground wire that was not connected on the BSM.
Old Dec 3, 2009 | 06:25 PM
GeronC's Avatar
Everything is good. Apparently the card i had was for the wireless stick-on.
Went to the dealership and talked to my service advisor. In about 2 min, one of the service techs came out and hooked his laptop up to the truck and pulled it off for me. He was actually the most helpful service tech i have ever talked to. He even asked me if i wanted to check anything else while he had me. I said heck yea! everything was grovy and my service advisor told me merry christmas! I was out $$$ free buddy!!! Thanks again!
