odometer goin bizerk
Old Mar 2, 2006 | 05:33 PM
bigsteve1206's Avatar
i have a 99 f150 with the digital odometer. i dont know whats up with it.. it still registers miles but the display cuts off and comes back on when it wants to. it can get kind of annoying when im driving at night. please help!!!
stevie
Old Mar 2, 2006 | 06:08 PM
Bartak1's Avatar
Somewhat of a common problem.
Check out this link
https://www.f150online.com/forums/sh...ttent+odometer
I had the same problem and that fixed it. Its been working good ever since I did it probably 2 years ago.
Old Mar 2, 2006 | 06:36 PM
davidshick2's Avatar
Unhappy
I have seen the link before that you are redirecting him to but I am wondering what he means by " Resolder this pin with a low wattage soldering iron." What is a low wattage solder iron. I have a welder brand pen type and a gun one will theses work
Old Mar 3, 2006 | 01:59 AM
hey thanks for the link. i thought i was the only person with the problem hence why i didnt do a search even though i search for anything that i need help with on my truck. i just got it yesterday with 131000 miles and it drives beautifully no rattles and id swear its a brand new truck. i think this chevy man has turned into a ford man but im still holding my breath as to see if anything goes wrong with it.. it was a gift so im "stuck" with it. as long as nothing goes majorly wrong with it (motor, or transmission) then ford has me sold. thanks again
stevie
Old Mar 3, 2006 | 06:49 AM
cobra909's Avatar
David, use your pen/pencil type iron for this. It is probably rated at something around 30 watts. The "solder gun" is usually rated at 100-200 watts and is too much power for this repair. You can actually use too much heat and lift the circuit board "tracks" off of the board. Good Luck.
Old Mar 3, 2006 | 06:59 AM
Thanks cobra I will try the pen thanks for the help.
Old Mar 11, 2006 | 12:43 PM
CAkid88's Avatar
Red face Same thing, but more
My odometer just started going on and off, but before this started, my trip odometer kept resetting every time I started my truck, but that's not all. My tach. and speedo would peg to the top for a couple seconds, drop back down to 0 for a couple seconds, then the tach would go to where it should be. I'm going to try that link, and hope it will fix all these problems at once. Keeping my fingers crossed.
Old Mar 11, 2006 | 02:49 PM
hmustang's Avatar
My old 2000 did the same thing it started doing it shortly after it hit 50k miles way back in early summer of 02 by the time I got rid of it in November of 05 it stayed off more than it did on. But funny thing is on the day I traded it in for my current truck it was staying on not showing problems so they could get the exact mileage on it instead of having to gues what it had.
Old Mar 11, 2006 | 03:46 PM
CAkid88's Avatar
Fixed the odometer, but not the tach.
Well, the fix on the cracked pin was easy enough, but it didn't fix the problem I am having with the tach. and Speedo. I looked the circuit board over very carefully, thinkin there might be something else cracked, no luck. At least now I can use my odo to see the crappy gas mileage I'm getting.
Old Mar 11, 2006 | 03:57 PM
CAkid88's Avatar
Cool By the way Bartak...
That sure is a sharp lookin truck ya got. I love the big speaker box in the back, but I'm not quite ready to take out my back seat. Right now I have 2 10"s in sepparate boxes, but they're not really under the seat. The only thing I would add to your truck is some nerf bars, mine came with them, and I love em.
Old Mar 11, 2006 | 10:56 PM
BLUE20004X4's Avatar
Mine does this too, but not if the cab is cold. In the summer, forget it. The problem is always getting worse. That was a great link to fix it, and one day I'll try it.
