Help with OBDII code RXAQ3P4
Old Feb 25, 2006 | 04:10 PM
4thatoy's Avatar
I ran my codes this morning, and my scanner came up with this code RXAQ3P4. Does anyone know what this is?
Old Feb 25, 2006 | 06:13 PM
metallion's Avatar
That doesn't look like any DTC I've ever seen. Are you testing the PCM or another module? I would check again. You should be getting a code that starts with a letter P (powertrain), C (chassis), or B (body), and usually four numbers behind it. Wonder if the code is for your scan tool? Let us know what you get.
Old Feb 25, 2006 | 11:57 PM
4thatoy's Avatar
Thank you for the reply.
I was using a SCT flash scanner. I can program different tunes with it. I reset the program on the truck and unlug the negative battery cable for a while. The light went off, but it might come back. I might have to make a trip to the dealership
Old Feb 26, 2006 | 08:22 AM
projectSHO89's Avatar
Probably time for a new scanner.
What year truck? If 04 or newer, the older scanners don't support the new CAN communications protocol.
Always identify your vehicle.
Steve
Old Feb 26, 2006 | 09:19 PM
4thatoy's Avatar
Thanks Steve,
I have a 2004 SCREW. Sorry. I'm new to the forums. I'm going to try my dealer.
