Reading a Schematic, HELP!
Old Feb 20, 2006 | 05:01 PM
nu-supercrew's Avatar
Need help with this. On schematic it shows wire going into fuse box. It is labeld: FUSE
31
20A would that translate to : Fuse position 31, 20 amp ?
Also, along a wire, the line has a solid circle on it and is labeld: S328 or S208 are these switches?
Thanks.
Old Feb 20, 2006 | 07:14 PM
GIJoeCam's Avatar
Assuming you're talking about the OEM fuse manual, yes, F31, 20A is fuse #31, 20 Amps.
S### are splices where two wires meet each other and are spliced together. C### are connectors. C###a or C###b are two connectors on the same module.
Does that help?
-Joe
Old Feb 20, 2006 | 08:11 PM
Sure does! Thanks.
