Losing power to entire truck.
Old Jan 20, 2006 | 01:09 AM
BrandonT's Avatar
I have a 97 F150 4x4 with almost 140,000 miles on it. I know it's been through some rough times before I bought it, but here's my problem. Every now and then when I turn the key to start my truck it loses power completely. The radio presets and time will reset. Tonight I went to start it and turned the key completely forward with nothing happenning. Turned it back and tried it again and it started after a slight delay. It just started doing this here lately. I have two amps and a scanner besides all of the stock stuff, but I didn't figure that would have anything to do with it. I just recently replaced the alternator so I know the battery is getting a good charge. The negative terminal connector on the battery is pretty corroded, would that cause it to lose connection so easily? I have replaced the positive side not too long ago.
If a connection was bad on the starter it wouldn't cause the whole truck to lose power would it?
Any ideas would be helpful.
Thanks,
BT
Old Jan 20, 2006 | 01:54 AM
SSCULLY's Avatar
The Neg side of the battery being corroded, could have something to do with it taking ( or not taking ) a charge.
Actually just because you have a new alternator, does not mean that the battery is takng the good charge. It could be a case of the battery is on the way out.
Try some baking soda mixed with water to clean the terminals, and maybe putting a trickle charger on the battery overnight, to see if it continues.
If so, maybe the battery is toast, and needs to be replace.
Just a few thoughts without any additional info.
Good luck, let us know what happens
Old Jan 20, 2006 | 02:03 AM
x2 corrosion is the biggest power draw
