Noise coming from dash
Old Dec 21, 2005 | 11:36 PM
neal95's Avatar
Got a question. I have an 03 F150. I started to hear what I believe to be a motor coming on somewhere in the dash on the passenger side. It will start and run about 15-20 seconds. It has done it right after I turn the truck off and while I am driving. It almost sounds like a motor to a small air compressor (like one you would plug into your cig lighter for a bicycle tire).
I would like to know if this is normal and why or do I have a problem. I just bought the truck in Oct.
Hope someone can help.
Old Jan 20, 2006 | 02:30 PM
northernnorm's Avatar
I'm not sure where the electrical system cooling fan is located in your truck, but mine is closer to the driver's side. I hear it when I use electrical power, ie. radio, when I have the key turned on, but engine off. It also runs for a few seconds whenever I shut the engine off.
Old Jan 20, 2006 | 02:32 PM
I'm not sure where the electrical system cooling fan is located in your truck, but mine is closer to the driver's side. I hear it when I use electrical power, ie. radio, when I have the key turned on, but engine off. It also runs for a few seconds whenever I shut the engine off. At least that's what I presume the sound is in my truck.
