Looking for the RAP module
Old Nov 17, 2005 | 02:45 PM
Mad Dog 05's Avatar
Does anyone know where the Remote Anti-theft Personality module is located in the 05 F150? I need to find the access code that is supposed to be there for my keyless entry system. I've read that it is either located under the dash on the driver side or it is behind the fuse box on the passenger side. Does anyone know for sure?
Old Nov 17, 2005 | 04:45 PM
ronco's Avatar
Mad Dog,
The module that you speak of accodording to my Ford tech is called vsm module. The module is located behind rear seat mounted on rear wall behind trim panel on Supercrew and Supercab. Regular cab I am told is mounted on the side trim panel behind driver seat. I have added LT handles on my truck and I am working on trying to get the keypad to work on my truck. I had my Ford tech hook computer to truck to try to activate keypad but cannot, he is working with someone through ford technical to see how to do this. Looks like maybe will have to replace module and get codes from ford using as built date. Hope this info may help you.
Ronco
Old Nov 17, 2005 | 07:51 PM
Mad Dog 05's Avatar
Originally Posted by ronco
Mad Dog,
Ronco
Thanks for the info, I've never heard of the vsm module. I will take a look to see if I can find it.
