multi-conductor recommendation
Old Nov 12, 2005 | 12:51 AM
tbzep's Avatar
I'm in the process of wiring some new emergency lights on my 2000. I want to use relays under the hood to activate them. I'll be using RadioShack 30A relays and their 275-731 illuminated switches.
Can you guys recommend a light multi-conductor wire to run from my overhead console to the relays under the hood? I need a total of six conductors to run four switches/relays with LED indicators.
I'm leery of using lightly insulated stuff that I've read about on other websites like cat-5 cable and telephone cable because constant vibration might wear through the insulation.
Old Nov 13, 2005 | 07:05 PM
b1miller's Avatar
Beldon and others make multi conductor instrumentation cable in the typical sizes you would need from 16 to 24 AWG. Shielded and un-shielded. It usually will have a 300V rated pvc jacket. Stop by your local electrical contractor. They usually have lots of scraps laying around they will give you. I believe Home Depot may carry some also.
