P0402 trouble code
Old Nov 8, 2005 | 01:07 AM
osunajr's Avatar
P0402 trouble code
Hi everybody,
I just got the "service engine" light on my 2002 4.6L F150. I bought an ODBII reader and the code stored in the computer is P0402. Has any one ran into this problem and what was the fix? I don't have the codes to decipher what is wrong with my truck.
Thanks for your help in advance!
Old Nov 8, 2005 | 08:23 PM
Bluegrass's Avatar
Your 402 code is telling you there is excess EGR flow.
The EGR is stuck off it's seat.
This should be causing a bit of a rough idle depending on how far open the EGR is stuck open.
Clear the problem, then clear the code with you scanner. Don't clear the code by removing the battery lead.
If you didn't fix it it will take 3 engine use cycles for the CEL to return so don't get excited until into the third time you use the truck.
Old Nov 9, 2005 | 09:04 AM
projectSHO89's Avatar
More likely a faulty DPFE than the EGR valve stuck open.
Both are possible, though.
Steve
Old Nov 12, 2005 | 03:51 PM
osunajr's Avatar
Hi Guys,
Do you know where the DPFE sensor is located?
Thanks!
Old Nov 12, 2005 | 10:52 PM
Bluegrass's Avatar
Drivers side, standing up on two small metal tubes in all it's glory.
Old Nov 13, 2005 | 05:18 PM
osunajr's Avatar
Thanks!!!
The DPFE sensor did the trick! no more service engine light!
