Changing My headlight bulbs
Hey,
I am getting ready to put in some aftermarket headlight bulbs and when I looked at the drivers side assembly it appears as though I will have to take off the air box and the coolant reservoir. Am I correct in this assumption or is there a trick to doing this. Thanks for any info you can provide.
The trick is to take the headlight assembly off
Look down on the assembly, and you will see a black lever on each side. Pull these straight up to release the housing. Then wiggle the housing out. Easy access to the headlight socket.
Welcome to the site! You will learn all you need here.
Look down on the assembly, and you will see a black lever on each side. Pull these straight up to release the housing. Then wiggle the housing out. Easy access to the headlight socket. Welcome to the site! You will learn all you need here.
Prior to installing the new bulbs, make sure you wipe them off with a clean cotton cloth. This will clean off any residual grease from handling. If not, the grease will create hot spots and lead to early failure.
